1965 chevelle backhalf bracket car
65 chevelle with art morrison ladder bar back half strange coil overs, new anti roll bar9” with 4.71 gears. 14x32 rear tire could fit bigger. 12 point cage with auxiliary helmet bars. Mid plate and motor plate. Tubular transmission crossmember. Has glass 1 piece tilt front end and glass rear bumper. Otherwise steel. Aluminum tunnel and tin work over back half the rest is steel. Factory dash with gauges fit in to old gauge ports. Have original cluster that was non functioning. Interior is all carpeted except for tunnel which is removable. Has nitrous express wet plate system. Can be jetted up to 300 but is set up for 100. Rarely ever sprayed for finish line use....
$15,000
Posted by: Rapidwelding
Post Date: March 25, 2018
Expires: July 15, 2018
More...
