Corvette
2005 tube chassis
88 compition fiberglass body 407 SBC Parker Machine Engine Dyno 860 HP 1 Four Barrel on Gas Runs 5.30's 1\8 mile 1.14 - 1.15 60 Foot Dart Little M Block Callies Crankshaft Dart Pistons Coated and Gas Ported Jessel Belt Drive All Pro Heads Titanium Valves Jessel Rocker System Moroso Dry Sump System Wulf Pump Magnafuel Pump MSD Electronics 1050 Holley Pro Stock Carb Parker prep Ron Davis Radiator with fan and shroud Meziere Water Pump Power Glide with Reid Case Coan 8" Convertor 1.80 straight cut Planitaries Tran Brake with Little Wizard Crossover Delay Box Electric RPM Shift Module with Solenoid Strange Heavy Duty Struts Strange Double Adjustable Coil Over Shocks Stange Master Cylinder Weld 15/16 wheels weld front wheels PLUS LOTS MORE $34,000 Posted by: hiler574 Location: FORT DODGE, IA Post Date: March 10, 2013 Expires: June 2, 2013 More... |
