Classified Feed Provided by RacingJunk.com
Corvette
Old Mar 10, 2013 | 09:22 PM
RacingJunk's Avatar
Former Sponsor
Default Corvette
2005 tube chassis
88 compition fiberglass body
407 SBC Parker Machine Engine
Dyno 860 HP 1 Four Barrel on Gas
Runs 5.30's 1\8 mile 1.14 - 1.15 60 Foot
Dart Little M Block
Callies Crankshaft
Dart Pistons Coated and Gas Ported
Jessel Belt Drive
All Pro Heads
Titanium Valves
Jessel Rocker System
Moroso Dry Sump System
Wulf Pump
Magnafuel Pump
MSD Electronics
1050 Holley Pro Stock Carb Parker prep
Ron Davis Radiator with fan and shroud
Meziere Water Pump
Power Glide with Reid Case
Coan 8" Convertor
1.80 straight cut Planitaries
Tran Brake with Little Wizard Crossover Delay Box
Electric RPM Shift Module with Solenoid
Strange Heavy Duty Struts
Strange Double Adjustable Coil Over Shocks
Stange Master Cylinder
Weld 15/16 wheels
weld front wheels
PLUS LOTS MORE
$34,000
Posted by: hiler574
Post Date: March 10, 2013
Expires: June 2, 2013
More...
