Classified Feed Provided by RacingJunk.com
Corvette
Old May 26, 2015 | 08:51 AM
RacingJunk's Avatar
Former Sponsor
Default Corvette
565 Warrior Series Racing Engine
$16,999.00
940 HP @ 7200 RPM, 765 FT LBS @ 6000 RPM
Block - Dart Big "M" Sportsman 9.800" Deck
Crankshaft - 4340 Forged Steel int. bal. 4.250" Stroke
Rods - Manley 6.535" with ARP 2000 Bolts
Pistons - Custom CP CNC Dome for 3xtra Heads
Bearings - Clevite 77 "H" Series
Rings - Total Seal File Fit Moly
Timing Set -RollMaster Double Roller
Balancer - ATI 7" Internal Balance SFI
Flexplate - 168 Tooth Internal Balance SFI
Cam - Comp Cams Mechanical Roller
Lifters - ISKY RED ZONE
Pushrods - 3/8" Manley 4130 Steel 1 Piece Design
Rocker Arms - Comp Cams Pro Magnum
Oil Pump - Speed Pro HV/HP
Oil Pan - Moroso Double Kick Out Steel
Cylinder Heads - Brodix "As Ca...
Posted by: Drag333
Post Date: May 26, 2015
Expires: June 9, 2015
More...
