1965 heater blower motor
I am having a problem with the heater blower. Replaced blower motor.(old one did not run) Now after checking circuits, switch, grounds, etc. it will run then shut off. If I replace the fuse, it will run and shut off ( fuse tests ok). I have replaced the rheostat in the heater box to no avail. Any suggestions? THANKS EVERETT
RE: 1965 heater blower motor
Found the problem with the blower motor. It eventually lead to other electrical "glitches." The whole problem stemmed from a corroded fuse block, connections, fuse terminals,etc. Replaced fuse block. Everything seems normal now. Just thought I would pass this on FYI.
glad ya found it. many thanks for getting back and letting us know
