How to test Fan Clutch for high temp. engagement
Old Jul 8, 2021 | 03:15 PM
Gortopan's Avatar
Default How to test Fan Clutch for high temp. engagement
65 coupe with 327 300hp. How can I test to see if the fan clutch is engaging at high temperatures? I read it should engage around 180 deg. F.
Old Jul 9, 2021 | 10:37 AM
I would use a heat gun and see if there's an increase in stiffness as you try to turn the fan blades. You can usually tell when it engages by the significant increase in fan noise also.
Old Jul 10, 2021 | 10:48 AM
Gortopan's Avatar
Thumbs up
Thanks I'll try it if I can get a heat gun to get the clutch to +180 deg. A have side pipes, don't know if I would hear the fan noise. :-)
Old Jul 10, 2021 | 12:01 PM
You can get a heat gun at Harbor Freight that will definitely on the high setting get the clutch thermostatic spring to 180°.
I think with the car sitting in the driveway and the hood open, you should be able to notice the change in speed if not the noise level.
Flying Low
Jul 21, 2008 11:15 PM
vetterz06
Jun 25, 2007 06:03 PM
AeroCEC
Feb 27, 2006 12:08 AM
Wifes81
Aug 15, 2005 11:50 AM
madride
Jul 22, 2005 06:40 PM
