Mid year side pipe heat shield
I bought a mid year side pipe inner black heat shield that I need to install on the outer aluminum cover. Does anyone know this is supposed to attach to the cover? I thought I had heard one time that it gets glued in place but I don't know if I would trust glue with the high heat and vibration, but I don't see any way of attaching it with hardware.:confused:
On my '69 factory side exhausts, it is attached w/ hardware. Best bet is to get a AIM (Assembly Instruction Manual) to see how the factory did it. |
Thanks 73shark. The manual shows the inner plastic shield and the outer aluminum shield as one part number, already attached to each other. I'll have to find a good glue that will stick to plastic and metal and can withstand the heat.
Might check w/ a body shop or muffler shop. Or contact a vendor and see what they use.
