starting a 63 that is in storage
Old Sep 19, 2020 | 10:11 AM
leethorp63's Avatar
Default starting a 63 that is in storage
Hi everyone,
My dad has a 1963 Corvette, Fuel Injection with a Rochester Carburetor ....it has been in storage & not started in 20 years. Unfortunately, I can see there is gas in the tank. Dad wants any recommendation on the proper procedure to attempt to start it. She's super pretty, and eventually will be mine so I am concerned. Any help is appreciated. Thanks, Lee
Old Sep 19, 2020 | 08:42 PM
kkupec02's Avatar
I would change the oil and radiator fluid. Then disconnect the fuel line to the gas tank. Start the car by running a line to a small gas can so gunk won't come up from the gas tank.
Old Sep 20, 2020 | 05:11 PM
I agree. I would also flush the entire cooling system when replacing the coolant.
Old Sep 21, 2020 | 02:46 PM
leethorp63's Avatar
But what about the gas that is already in the lines? Won't that be a factor also?
Old Sep 21, 2020 | 04:18 PM
kkupec02's Avatar
You will use a new rubber fuel line going from a gas can on the floor directly to the carb to avoid as much old gas as possible. You will not be able to avoid ALL of the old gas.
Old Sep 22, 2020 | 12:59 AM
You should also pull the distributor and use a special shaft to to drive the oil pump an prime the engine to avoid a dry start. I've seen them on Amazon. Otherwise you'll have a dry start and could damage some bearings.
Old Oct 25, 2020 | 06:01 PM
JohnfromSC's Avatar
Also, before you drive it, you will have to flush the brake lines of the old fluid. You should really inspect the lines, inspect the wheel cylinders and insure that the brakes are free, and that there are no fluid leaks. Best to put jack stands under half the car at a time to do the wheel inspections with the wheels off. When you are confident there are no leaks change all your fluid. Buy 2-3 times as much as you think you need because after 20 years you really have to flush the system especially if any rust comes out in the fluid.
Old Oct 26, 2020 | 01:29 AM
RacingJunk
Jan 7, 2016 03:28 PM
BB66
Apr 18, 2013 08:53 AM
Skinner
Dec 19, 2007 05:32 AM
eurogrp1
Apr 25, 2007 01:53 AM
Slim
Feb 8, 2007 08:56 PM
