1980 horn problem
Which, if any, is the fuse for the horn? Can anyone enlighten me on troubleshooting the horn?
Welcome to the forum. Can't help on the fuse. Old horns usually quit working due to non-use. I've had some luck by tapping and running the adjusting screw in and out w/ 12V applied to the horn.
You might want to check the contact inside the steering wheel. I have found these to be bad or corroded on a couple ones I have worked on.
