1980 horn problem
Old Aug 22, 2009 | 01:16 PM
battwins's Avatar
Default 1980 horn problem
Which, if any, is the fuse for the horn? Can anyone enlighten me on troubleshooting the horn?
Old Aug 22, 2009 | 03:27 PM
Welcome to the forum. Can't help on the fuse. Old horns usually quit working due to non-use. I've had some luck by tapping and running the adjusting screw in and out w/ 12V applied to the horn.
Old Aug 24, 2009 | 04:02 AM
watwheel's Avatar
You might want to check the contact inside the steering wheel. I have found these to be bad or corroded on a couple ones I have worked on.
pelago
Apr 29, 2013 01:22 PM
84blackice
Oct 12, 2007 10:46 PM
gizwilly
Oct 19, 2006 01:47 AM
pebblesjetson
Nov 26, 2005 08:49 PM
jdavis
Nov 10, 2005 02:30 PM
