1981 corvette .
Old May 18, 2006 | 01:07 AM
Gmoney69's Avatar
Default 1981 corvette .
Hey guys, i just purchased a mint 1981 vette w/ 53,000 original miles..
i was just wondering if theres any parts you guys would recommend for getting some more HP out of her. Right now it has a holley carb, edelbrock intake, heads are milled down, Has a bigger cam in it nothing crazy. the exhaust is stock right now w/ the cat removed, any suggestions on that for the biggest HP gain?(was thinking sidepipes)
i know the car weighs in at about 3300 so i was thinking about removing the spair tire and maybe the ac but im not sure. Would it make a big diffrence if i removed the AC belt off of the crank? I want to keep the car as a nice daily driver, but have some power behind it when i want to have some fun. it is a 3 speed automatic
If theres any other tricks for squeezing some HP out of this baby i would appreciate it if you would let me know :-)
thanks in advance, Jay.
Old May 23, 2006 | 07:03 PM
toml14's Avatar
Default RE: 1981 corvette .
Sounds like the other guy was on the right track as far as engine mods. Mine has all the same with the exception of the head work. It really makes a difference over stock performance which I take it you never experienced. Get rid of everything you dont want-it will all add something. I have the A/C and power steering still but the pollution pump was yanked.
Probably wouldn't hurt to go with a true dual exhaust system like the sidepipes you mentioned. I bought a kit from MidAmerica before I did the engine mods and the mid range power went up dramatically.
Other than that it is only a very conservative 350 with low compression in the car so changing the engine to something more high performance might not be a bad idea. Im looking into something a little hotter for mine already!!!
Old May 24, 2006 | 02:00 AM
Gmoney69's Avatar
i was looking into the edelbrock heads, w/ 65cc domes, and hooker headers with sidepipes.
do you guys think these mods will really bring out the HP in the vette? [:@]
also, i see that you can upgrade the ECU/Computer, im pretty sure its hooked up because the car needs it to run, do any of you guys have experience w/ upgrading the ECU?
AmericanCarCraft
Mar 28, 2013 10:35 AM
RacingJunk
Feb 24, 2013 03:20 AM
rm1sner
Apr 13, 2012 05:41 AM
rmf913
Aug 23, 2008 09:09 AM
leebay
Aug 29, 2005 11:58 PM
