74
Old Nov 17, 2012 | 11:55 AM
SCHOON's Avatar
Default 74
OK here's the deal.
74 still is breaking up on both sides under load.
Starts and runs fine until I give it 3/4 pedal or more.
New plugs and wires
New HEI distributor/set timing
New fuel filter and new gas
Carb is HP 700CFM DP
Turned mixture screws in and engine died, means power valves ok
I give up Any ideas welcome
Old Nov 17, 2012 | 03:38 PM
My experience w/ that type of problem has usually been on the electrical side. Moisture in the dist., cracked cap, bad wires, etc. I know most of those are new but sometimes new parts are bad.
Old Nov 17, 2012 | 04:35 PM
SCHOON's Avatar
Shark,
It did this with the old stuff now it is doing it with the new stuff.
I would think even if I had a problem with the new stuff it would be a little different.
I am going to swith carbs and see if I still have the prioblem.
Maybe it could be vacumn but that would make the idle rough
This ones got me good
Old Nov 17, 2012 | 07:37 PM
Didn't realize problem existed before new parts. Going back to old carb is a start. Or did the problem exist w/ it too.
BTW what's an HP carb?
Old Nov 18, 2012 | 04:11 PM
SCHOON's Avatar
This is a new problem that started after I had the Vet painted.
Infact it started the same day I picked up the Vet.
HP carb, I meant HDP Holley Double Pumper.
This problem on happens when I get heavy on the gas.
I am think that maybe the seconday power valve is sticking?
Anyway I am going to try switching carbs and see what happens.
Stay tuned
Old Nov 18, 2012 | 06:08 PM
Don't know what mods you have on the engine but a DP may be too much carb. Is it a 750 cfm? Mechanical or vacuum secondaries?
If you've got a working Q-jet that'll fit the manifold, I'd try that.
Old Nov 19, 2012 | 06:35 AM
SCHOON's Avatar
700 cfm holley mechanical secondaries
Old Nov 19, 2012 | 11:12 AM
Does it continue to break up if you stay in it or does it level out at a constant throttle? I'm think maybe the mechanical secondaries are dumping too much gas in it. A 350 at WOT takes about 650 cfm.
Old Nov 19, 2012 | 03:27 PM
SCHOON's Avatar
If I stay on it just keeps gettin worse.
This carb has been working fine for 5 years.
Old Nov 19, 2012 | 06:37 PM
Sort of sounds like mine before I tore it down and found the rear cam lobes worn down. It just wouldn't run over about 3,500 rpm. Sounded like crossfire in the wires but they were new. Haven't reinstalled so don't know if rebuild fixed the problem.
