82 Remodel, Rear Window Seal
Old Dec 17, 2007 | 01:02 PM
myckey2u's Avatar
Default 82 Remodel, Rear Window Seal
I recently purchased my first Corvette...waited 25 years. Bought it from the original owner. It's an 82, with 82,000 miles. The body is straight and runs great. I want to find out about driving it on a regular basis, does the weather affect the fiberglass (live in a hot/cold environment) and how do I go about getting a quality paint job. The car has sat in a garage for the past 10 years. Original paint job. Also, the back window leaks around the seal. Where can I find a new seal. Ecklers and Mid America weren't ablt to help me find one. Any help would be appreciated. I do alot of my own work and plan on replacing seals etc on the front end, including ball joints, bushings and the idler arm. Any suggestions? Thanks for your input~
Old Dec 17, 2007 | 01:35 PM
wrwalke's Avatar
Default RE: 82 Remodel, Rear Window Seal
Someone correct me if I'm wrong here... But the rear window is just placed into the frame with the black gunk, like a windshield. The trim pieces are just there for show to cover the adhesive. You can take it to a windshield/automotive glass shop, and have them either scrape and repack, or pop out the glass and re-install it. Not a bad job, usually pretty cheap (since they have the tools and experience).
bill.
Old Dec 17, 2007 | 02:31 PM
watwheel's Avatar
Yep!! Black sealant prevents leaks. That's all there is to it. Definately a do-it-yourself project. Just be careful with the trim pieces as they are somewhat fragile.
Old Dec 17, 2007 | 02:56 PM
mike82's Avatar
Unless it is the Collector Edition. Then it has a hatchback and a seal that does(can) leak.
Old Dec 17, 2007 | 07:35 PM
myckey2u's Avatar
The window is operable...not fixed. The seal needs to be replaced. It got hard when the car was sitting and now has shrunk a bit and created a open spot.
Old Dec 19, 2007 | 02:42 PM
Welcome to Corvette Forum.
Might check with places like Dr. Rebuild and Corvette Rubber.
ercriss
Jan 28, 2014 07:38 PM
jerome
Feb 26, 2013 04:10 PM
dyoung9
Jan 11, 2008 10:59 PM
Bagpipingjake
May 18, 2006 02:10 AM
wllmlacey
Nov 22, 2005 01:58 PM
