De-Smogging a 1981 C3
Old Sep 24, 2024 | 10:37 AM
mwc3's Avatar
Default De-Smogging a 1981 C3
To de-smog a 81 C3 do I have to change the Carb and the Distributor ?
Old Sep 24, 2024 | 04:20 PM
Welcome to the forums. Yes you will need to remove both. The carb and distributor are now both controlled by the ECM. You will need a pre 81 carburetor (non electric) and a pre 81 distributor 4 pin module with a mechanical and vacuum advance.
Old Sep 24, 2024 | 04:25 PM
Also the ECM fuses will need to be removed or the check engine light will stay on.
Old Sep 29, 2024 | 07:26 PM
How is the desmoging going?
Old Sep 30, 2024 | 06:24 AM
mwc3's Avatar
Default 81 Desmogging
Thanks for asking. I have all of the external stuff removed and the stainless tubes in the exhaust cut off and tig welded closed. Ordering a earlier distributor today. When I get that installed and the timing set I will see how the carb is going to work with the sensors unplugged !!
Old Sep 30, 2024 | 07:48 AM
Are you replacing the carburetor also with a pre 80s non electric carb also?
Old Sep 30, 2024 | 12:20 PM
mwc3: Welcome to the forum.
Are you going to true duals with no cats?
gizmolucy
Sep 12, 2018 12:21 PM
Jawsh SeKsy
Jun 23, 2015 06:27 PM
mrrx8
Oct 21, 2008 08:53 AM
blueshark
Apr 26, 2007 10:50 AM
nats
Dec 13, 2005 04:28 PM
