need correct part numbers
Can anyone help me determine what the correct part numbers are for a 72 corvette, convertible, 350, auto tranny, A/C for the following items?????
[ul][*]distributor[*]intake manifold[*]heads [/ul] |
RE: need correct part numbers
Are you looking forthat car's specificparts?
There are many choices for each item you have listed. You can take all that stuff off the '69 Camero, and they will fit. Or any small block Chevy for that matter.:) |
Source: 1953-1974 Corvette Parts Catalog dtd 1974
Distributor: 1112050 for base engine, 1112167 for LT-1 Intake manifold: 6262932 for base engine, 3991004 for LT-1 Heads: 6272070 for base engine, 6272068 for LT-1 Hope this helps. Be aware that P/Ns may have changed since then and that you'll probably have to go to the aftermarket to get them unless you get lucky. Your parts guy has the capability to check inventories at other dealers around the country. |
Great info............thanks much. This is very helpful
