need correct part numbers
Old Jan 7, 2007 | 04:43 PM
brickyard02camaro's Avatar
Default need correct part numbers
Can anyone help me determine what the correct part numbers are for a 72 corvette, convertible, 350, auto tranny, A/C for the following items?????
[ul][*]distributor[*]intake manifold[*]heads
[/ul]
Old Jan 7, 2007 | 06:59 PM
Default RE: need correct part numbers
Are you looking forthat car's specificparts?
There are many choices for each item you have listed.
You can take all that stuff off the '69 Camero, and they will fit.
Or any small block Chevy for that matter.
Old Jan 9, 2007 | 11:04 PM
Source: 1953-1974 Corvette Parts Catalog dtd 1974
Distributor: 1112050 for base engine, 1112167 for LT-1
Intake manifold: 6262932 for base engine, 3991004 for LT-1
Heads: 6272070 for base engine, 6272068 for LT-1
Hope this helps. Be aware that P/Ns may have changed since then and that you'll probably have to go to the aftermarket to get them unless you get lucky. Your parts guy has the capability to check inventories at other dealers around the country.
Old Jan 10, 2007 | 08:41 PM
Great info............thanks much. This is very helpful
red90vettesc
Feb 26, 2007 09:37 AM
tonyrbp
Aug 29, 2006 06:02 PM
achin422
Aug 13, 2006 01:39 PM
C3 Starship
Jul 31, 2006 12:07 PM
Gkayea
Mar 11, 2006 01:52 AM
