new member
Old Apr 30, 2014 | 06:01 PM
jayman's Avatar
Default new member
77 done much work on my own.this one stumps me.replaced half shaft u joints.I know there correct.when I really put the heat to her I get a thumping on only the right rear.as soon as I let off throttle and I'm still rolling it stops.any ideas?
Old May 1, 2014 | 02:24 PM
Did this start right after the U-joint replacement? First thing that comes to mind is wheel bearing.
Old May 1, 2014 | 04:42 PM
jayman's Avatar
Yes.wouldn't it b all the time not just when I'm in the throttle if wheel bearing?
Old May 1, 2014 | 08:08 PM
Not necessarily. You didn't lose any of the needle bearings when installing the new U-joints?
Old May 2, 2014 | 05:51 AM
jayman's Avatar
Had a machine(race) shop replace them then I put them back in.would it only thump when there is touted on the shaft?
Old May 2, 2014 | 11:03 AM
Not sure what "touted" is.
But if the shop wasn't familiar w/ the correct procedure for installing, they may have messed it up.
Old May 2, 2014 | 06:23 PM
jayman's Avatar
Sorry that should have read Tourqe.dam computer won't let me say that.don't know this was a high performance speed shop.friend told me today could b cap misalignment.have not taken the time to look.Thanks for your time
Old May 2, 2014 | 09:47 PM
Hope you find the problem. Let us know what you learn.
Old May 31, 2014 | 10:41 AM
jayman's Avatar
Still got trouble took it all apart.put it back together still thumps.maybe it its wheel bearings.do they just go?no issues before.
Old May 31, 2014 | 08:32 PM
Try swapping the two rear tires and see if it stays the same or goes w/ the tire.
