puffs of smoke
Old Aug 18, 2007 | 04:01 PM
  #11
Default RE: puffs of smoke
ORIGINAL: batesy80
Thanks all, I don't feel as bad as the guy in the C4 I saw today. He had smoke every time he got on it
That's rings, if gray or white. [&o]Too rich if it's black.
Old Aug 19, 2007 | 07:11 AM
  #12
78buckshot's Avatar
Only one other thought I have here, water/antifreeze in the combustion chambers will also cause white smoke, you could tell the difference between oil and water by the odor of the smoke. Also if you have coolant leaking into the chambers you would also be having some cooling system issues depending on the severity of the leak.
Old Aug 19, 2007 | 01:07 PM
  #13
Good point Buckshot, anti freeze will def give off it's own type of smell when leakin' into the combustion chamber. Check your oil for whiteish residue. Also look at the radiator cap for signs of residue.
Old Aug 20, 2007 | 03:27 PM
  #14
SCHOON's Avatar
Maybe a dark gray. I know I am not blowing oil my engine is like new and checked out fine.
When my power valve went out I did see black smoke and it smelled like gas.
Sometimes at start-up when I get the gray smoke it smells like gas not oil.
Old Aug 20, 2007 | 04:18 PM
  #15
batesy80's Avatar
Mine is definitly oil, I will inquire my corvette mechanic and get his opinion on as well. I'm sure a lot of corvette owners are in the same situation or similar. Only a couple more months to drive it so I'll deal with it then.
Old Aug 26, 2007 | 09:34 PM
  #16
ORIGINAL: batesy80
Hey guys, I have an 80 L48 and when its been running for a while or better yet , gone for a ride, on restarting it blows a small puff of smoke. I was told it most likely needs new valve seats. I just changed over to syn. oil but it smoked before that,It has 65,000 so called orig. miles on her, other than that she runs great, but want to get it fixed before it gets worse. Any thoughts that might help? Thanks Scott
Worn valve stem seals don't make for that puff of smoke on a re-start. UNLESS, there's no seal at all left on the stem. Even then, a better worn-seal indicator is the puff of smoke on a COLD motor, after sitting overnight, and hardly ANY smoke on warm motor re-starts.
Old Aug 30, 2007 | 06:07 PM
  #17
batesy80's Avatar
Talked to a corvette machanic the other day , to pick his brain he said that it was just seals and would not hurt anything at this pointand could replce for $350 but if the seats are worn than it could still smoke. changing the seats require pulling the heads, guess I'll waiton that for now,might want to do something else to the engine while it's open. Batesy
Old Aug 30, 2007 | 07:45 PM
  #18
78buckshot's Avatar
Hi Scott, I think you might be confusing valve seats with valve guides. Burned or worn seats or valve heads (these two seal together when the valve is closed) wont cause a smoke problem. Worn valve guides and/or stems will let excess oil into the combustion chamber and you will see the smoke your describing. If oil consumption is severe, 1500 miles or less per quart, then you would consider a "valve job". This would include correcting the stem to guide clearance, refacing the seats and valve face, new seals and possibly other work on the valve train depending on wear. The heads would have to be removed to perform this work. If it's just a little smoke on start-up then I would hold off until your ready to do other engine work.
Old Aug 30, 2007 | 07:52 PM
  #19
If you have an air compressor, replacing the valve seals is not that tuf. Need a valve spring compressor and an adapter to hook your air to the spark plug hole. The seals are about $.50 ea.
If you replace the seals, I'd recommend replacing the valve springs if the engine has over 50K. Chevy makes a HD spring but they don't put them in Corvettes. Found that out after breaking a couple.
my76
May 2, 2007 11:39 PM
wingervette
Nov 26, 2006 11:26 AM
mypetu39
Aug 16, 2006 03:48 PM
Bagpipingjake
May 17, 2006 11:14 PM
papa2
Dec 21, 2005 12:05 PM
