Rear axle shaft noise
I have a 79 that has a noise coming from the rear, just had a 4 wheel alignment done. The drivers side rear inner ujoint u bolts are scrubbing on the differential case. What are the possible causes and solutuons? It only makes the noise occassionally and only at speeds at idle.
Sound like the ends of your axle is wearing out. Jack up that side of the car and grab the wheel and try to push it in and out and see how much it is moving in and out of the rear. Should be very little. If it's alot, time for a new axle.
O.K., it's not tomorrow yet.
I just looked it up in my manual. It is quite a job, complete removal of the carrier assembly. The dif housing can be left in place. The bearings have to be removed from the inside out. You need to get inside to remove the yokes too. There are some adjustments to be made when it all goes back together. You may have to buy some tools to do a propper job.
I highly suggest that you pick up a manual for your Vette. I got mine from Ecklers. www.ecklers.com You can get a manual for your specific year of Vette. Every Vette owner should have one. Ya might want the factory assembly manual and wiring too. I havethem, and they are indespencable.
Sorry that I don't go into any detail, [&o]I would have to write about 4 pages for an indepth explanation. [&:]
Here's what one vendor has: http://www.vansteel.com/index.cfm?fu...formsearch.cfm
Before you open it up, I'd try putting in a bottle of GM Positrac additive and then do some figure 8s in a parking lot to work it in to the clutches. May not do any good but it's easier and cheaper than tearing down and rebuilding if it doesn't need it.
