rear end noise
installed right side yoke in 1974 corvette.now there is a tapping noise in the rear end.What is the likely problem?
Bearing, clutches,. . .? Never having done that operation, really can't help you. Maybe somebody else here will see this and put forward some ideas. |
Did you drop the yoke and have to put needle bearings back in place? Check your "U" joint for slack or miss alignment ( not seated properly in yoke)
