rear end noise
1968 through 1982
rear end noise
Nov 10, 2017 | 09:54 AM
billyraymorrison
Nov 2017
rear end noise
installed right side yoke in 1974 corvette.now there is a tapping noise in the rear end.What is the likely problem?
billyraymorrison
Find all posts by billyraymorrison
Nov 11, 2017 | 03:44 PM
73shark
Apr 2006
KC, MO area
Bearing, clutches,. . .? Never having done that operation, really can't help you. Maybe somebody else here will see this and put forward some ideas.
73shark
Find all posts by 73shark
73shark
Apr 2006
KC, MO area
73shark
Jan 24, 2018 | 01:30 PM
C3 Starship
Jul 2006
Reno, Nv.
Did you drop the yoke and have to put needle bearings back in place? Check your "U" joint for slack or miss alignment ( not seated properly in yoke)
C3 Starship
Send a private message to C3 Starship
Find all posts by C3 Starship
Engine Code
09:53 PM
