Rear lights problem
Old Jun 6, 2007 | 08:03 PM
Shipwreck's Avatar
Default Rear lights problem
So I recently acquired my 1st vette (74 coupe) and I am having trouble with the back lights. Reverse lights work, running lights work, one brake light works, and neither of the blinkers or flashers work. Any advice on where to start ( not the bulbs or the fuses)?
Old Jun 6, 2007 | 08:38 PM
pg's Avatar
Default RE: Rear lights problem
Hi Shipwreck and welcome to the forum.
For the turn signals you should check the "Flasher", it's under the dash on the passengers side.
For the brake light problem pull the bulb and see if you have 12 volts at the pigtail, if not trace the wire, it might be broken. Hope that helps, PG
Old Jun 7, 2007 | 11:34 AM
Also check the lite sockets for corrosion. I always coat new bulb bases with silicone grease to help prevent this. Also works on keeping spark plug wire boots from sticking to the plugs and cap.
Old Jun 9, 2007 | 12:38 PM
Shipwreck's Avatar
Hey! Thanks alot for the tips got all the lights working now. Was a mixture of bad flashers, one open in the wiring, and bad bulbs... hahaha. Thanks again!
petemoss
Feb 21, 2014 07:54 PM
miked0002
Oct 2, 2013 02:07 PM
shevey
Sep 23, 2008 10:19 PM
IVAN1215
Technical Diagram Help
Sep 24, 2007 01:50 PM
ice11vette
Nov 2, 2005 01:37 AM
