Rear spring bushings
I installed new bushings on the rear springs today and had a slight problem with the holes not lining up and had to use a clamp to move the spring over to get it together. Is this because the car is on jack stands and the trailing arms are just hanging there. I noticed that the strut rods were sitting on my exhaust pipes holding them up some. Is this normal for the holes not to line up when doing it this way?
Did you have a jack under the end of the spring with a C-clamp on the spring to keep it from sliding up like it shows in the service manual?
Originally Posted by 73shark
(Post 77219)
Yes, and the bolt holes did’nt lineup before I even started. |
It's been awhile since I've done this. Which bolt holes are you talking about not lining up?
(Post 77224)
Is it the same on both sides?
(Post 77226)
I guess a picture would help then.
(Post 77228)
Here https://cimg4.ibsrv.net/gimg/www.cor...1bea2786a.jpeg This is the best I could get is a picture |
You need to get it off the jack stands and let the suspension settle out and I the spring should be almost flat with just a slight arch in it. When it's resting on the floor again, the strut rod should not be touching the exhaust pipes.
Is that a new spring by the way? |
