Rear spring bushings
Old May 31, 2020 | 06:43 PM
734me's Avatar
Default Rear spring bushings
I installed new bushings on the rear springs today and had a slight problem with the holes not lining up and had to use a clamp to move the spring over to get it together. Is this because the car is on jack stands and the trailing arms are just hanging there. I noticed that the strut rods were sitting on my exhaust pipes holding them up some. Is this normal for the holes not to line up when doing it this way?
Old Jun 19, 2020 | 09:48 AM
Did you have a jack under the end of the spring with a C-clamp on the spring to keep it from sliding up like it shows in the service manual?
Old Jun 19, 2020 | 08:50 PM
734me's Avatar
Yes, and the bolt holes did’nt lineup before I even started.
Old Jun 19, 2020 | 09:55 PM
It's been awhile since I've done this. Which bolt holes are you talking about not lining up?
Old Jun 20, 2020 | 12:24 AM
734me's Avatar
The holes on the spring and the trailing arm. When looking at it from the side the bolt is at a slight angle and the holes don’t line up. If I can I will post a picture.
Old Jun 20, 2020 | 09:55 AM
Is it the same on both sides?
Old Jun 20, 2020 | 11:03 AM
734me's Avatar
yes both sides look the same
Old Jun 20, 2020 | 03:15 PM
I guess a picture would help then.
Old Jun 20, 2020 | 05:41 PM
734me's Avatar
Here
This is the best I could get
is a picture
Old Jun 20, 2020 | 08:02 PM
You need to get it off the jack stands and let the suspension settle out and I the spring should be almost flat with just a slight arch in it. When it's resting on the floor again, the strut rod should not be touching the exhaust pipes.
Is that a new spring by the way?
