Speedo KIA?
Old Sep 25, 2007 | 11:59 PM
NickD's Avatar
Default Speedo KIA?
Hey all, I finally picked up my "new" old vette. A 74 thats been shown a lot of love over the years... Anyways, I have been driving it around for about 2 months and all of the sudden the speedometer stopped working. I got under neath the car to check the connectgion at the transmission & verified that it was still connected, I "jiggled" it around and the the speedo worked for a little while, mainly at higher rpm's but once again, it has stopped working. Could this be a symptom of a bad cable or bad speedo gear? or could it be that my headlight fluid is low? Or possibly that my air freshner needs to be changed? any info would sure help, thanks.
Old Sep 26, 2007 | 07:34 AM
Default RE: Speedo KIA?
My first suspect is that your muffler bearings have gone bad. [&o]My second thought would be the cable. It may be broken inside and the ends of the windings may be catching on each other, which is why it worked again for a short time after "jiggling" it. If not that, your tail lights are out of alignment.
Old Sep 26, 2007 | 11:32 PM
Another possibility besides the head itself would be the speedo gear in the tranny. It's plastic and relatively easy to take out and check.
Old Sep 26, 2007 | 11:53 PM
or...... the thingamaflitchy isn't seated right in the dumajigger housing and thechingadarra bearings are warn and out of hooozey!
But it really sounds like the cable is shot to me. Cheers
Old Sep 30, 2007 | 07:26 PM
1974corvetteowner's Avatar
hey Nick I am having the same problem with my 74 when you figure it out can you post what the problem was for others (espically me)
Thanx Doug
Old Oct 1, 2007 | 12:19 AM
Wedge's Avatar
If it is the drive gear, make sure you get the right one. I have taller tires on mine, and put in a stock 22 tooth gear. I did gain 13 mph at 70. Who needs stickers when you can go faster with the wrong gear...eh Dave...
Later
Wedge
[align=left] [/align]
86 Ironhead
Dec 31, 2023 04:38 PM
Wedge
May 28, 2007 10:24 PM
hdstickel
Mar 27, 2007 10:54 PM
DOZER59044
Feb 27, 2006 06:38 PM
johnc
Nov 5, 2005 07:25 PM
