Speedometer cable transmission leak
I have a 1977 Vet with an automatic trans. Its leaking transmission fluid from the speedometer cable. After taking apart I don't see how it would not leak. There appears to be no form of seal around the gear shaft to keep the fluid from passing through to the cable. Am I missing something?
Neild |
Shouldn't there be an O-ring that the gear shaft goes thru?
Leaking speedo cable
Its actually a seal. And I found that it wasn't seated all the way into the bullet. I posted before and after pictures. This has fixed the problem.
Great, thanks for the follow-up. Don't see the pics tho.
Your right. My apology's. It appears I've posted the same thing twice. Here's the link to the other post that has the pictures. https://www.corvetteforums.com/forum...le-leak-18914/
