Speedomitor cable transmission leak
Old Nov 3, 2019 | 04:27 PM
Nbingham's Avatar
Default Speedometer cable transmission leak
I have a 1977 Vet with an automatic trans. Its leaking transmission fluid from the speedometer cable. After taking apart I don't see how it would not leak. There appears to be no form of seal around the gear shaft to keep the fluid from passing through to the cable. Am I missing something?
Neild
Old Dec 23, 2019 | 06:45 PM
Shouldn't there be an O-ring that the gear shaft goes thru?
Old Dec 23, 2019 | 07:42 PM
Nbingham's Avatar
Default Leaking speedo cable
Its actually a seal. And I found that it wasn't seated all the way into the bullet. I posted before and after pictures. This has fixed the problem.
Old Dec 24, 2019 | 12:23 AM
Great, thanks for the follow-up. Don't see the pics tho.
Old Dec 24, 2019 | 10:32 AM
Nbingham's Avatar
Your right. My apology's. It appears I've posted the same thing twice. Here's the link to the other post that has the pictures. https://www.corvetteforums.com/forum...le-leak-18914/
Nbingham
Nov 18, 2019 09:52 AM
riley6riley
May 10, 2009 01:49 AM
mypetu39
Sep 12, 2006 11:43 AM
Clayton
Jul 2, 2006 06:54 PM
johnc
Nov 5, 2005 07:25 PM
