Stroker oil pan
Old Jan 2, 2008 | 04:17 PM
78buckshot's Avatar
Default Stroker oil pan
I'm looking for a little help from you guy's that have built small block strokers. I'm using an Eagle cast crank w/3.75 stroke and the factory 5.7 in. rods, this is an internally balanced rotating assembly. It's fitted to a mid seventies 350 block, will the stock 350 oil pan clear the crank or do I need a stroker pan or will a pan from a small block 400 be any different than the 350 pan? Also while I'm on the subject, in a 350 build-up a few years ago I used a big block oil pump with a pick-up that fit the small block pan, do you know if this kit is still available, I know I used a Melling pump, I guess I could call them to see what they have. Thanks.
Old Jan 3, 2008 | 09:46 PM
DeeVeeEight's Avatar
Banned
Default RE: Stroker oil pan
PM sent
[sm=icon_cheers.gif]
Old Jan 3, 2008 | 09:47 PM
Banned
Yes a stock pan is fine. Believe it or not, we usedmy old steel stock pan frommy 350 block and "clearanced" it for the longer stroke. In simpler terms, a hammer was used tobend some of the metal on the baffles in the panto make room for the longer stroke, after a test fit all was fine. Good luck with your build! Post some pics of your progress if you can, we eat 'em up on the forum!
Old Jan 4, 2008 | 05:38 PM
78buckshot's Avatar
Thanks for the info DV8, did you have to clearance the pan at the rails or just the baffle? I'll be shopping for a new pan but I want a plain steel job and don't see the need for the high dollar so called stroker pans.
Old Jan 5, 2008 | 11:29 AM
Banned
Sorry, I don't remember..... Wemodified whatever wasn't clearing after the test fit. I do remember that it did not take much doing....
Old Jan 5, 2008 | 11:44 AM
78buckshot's Avatar
OK, thanks for the help, it can't need much to clear since it's only a 1/4 in. more stroke than stock.
WHIPSrx7
Aug 2, 2006 06:16 PM
lumpsdady
Apr 16, 2006 11:49 AM
paulbon
Apr 4, 2006 12:25 AM
paulbon
Mar 28, 2006 02:52 PM
dph
Feb 16, 2006 11:21 PM
