tires and rims
New to this forum , i have a 73 coupe that i am in the last stages of building . i am looking at 2 piece torque thrust d rims and want to know how wide i can go with front and rear rims and tires with out rubbing i will be using 15" rims.
thanks for any help
thanks for any help
Stock was 15x8 (15x7 in the first years), with 4" backspacing and a 5x4.75 lug pattern.
You can go to 4.5" backspacing without rubbing on some (but from what I have hear, not all) C3's. A 15x9 with 4.5" would be about as radical as I would want to go though without some careful measurement and fitting. It sucks when your $2000 set of rims and tires starts rubbing the wheel wells on bumpy roads.
I know there are some C3's out there with 8" wide on the front and 10" wide on the back, but I forget where I saw it (other than it did require some work).bill.
thanks , what about tire size ? would also like some ideas about a good all around street tire that sticks good
i am not to worried about mileage 10,000 miles or so would be good and the car will never be driven in the rain
