Trouble finding oil filler cap
Old Aug 27, 2007 | 07:10 PM
Dogcow750's Avatar
Default Trouble finding oil filler cap
Became the proud owner earlier this summer of a '79 L48 (82 body), wet black. The previous owner had the oil changed before the sale, and now the stick reads on the low side. But I can't find the filler cap. Any ideas?
Thanks,
Sam
Old Aug 27, 2007 | 07:22 PM
Default RE: Trouble finding oil filler cap
Welcome to CF, Sam!
Hmmmm....It should be in the valve cover. If you have the old style intake manifold,it should be sticking up between the thermostat housing and the carb.
Old Aug 27, 2007 | 07:31 PM
78buckshot's Avatar
Well DogCow, the stock valve covers had the oil fill in the left cover, just a quarter turn steel cap. if the valve covers have been replaced with after-market then it could be in either side or may not even have a oil fill. If the engine still has a PVC valve in the valve cover you can use that hole to get oil in the motor, just use a funnel small enough to fit the PVC grommet.
Old Aug 27, 2007 | 07:34 PM
78buckshot's Avatar
Whadya think Dave? someone put old style valve covers on it and a new intake without thinkin' of havin' to put oil in her?
Old Aug 27, 2007 | 07:41 PM
78buckshot's Avatar
That Dogcow750 handle reminds me of the Kawasaki 750 three cylinder of the mid seventies, we called 'em cow 350's, 500's, 750's.
Old Aug 27, 2007 | 07:42 PM
Could be, Bubba strikes again, eh? [sm=icon_rofl.gif]
In that case, pull the distributor and pour the oil down the hole.
But then again, ya could get a real tiny hose and funnel and fill through the dip stick hole.
Sorry Sam we're not makin' fun, just havin' some, O.K. ?
Old Aug 27, 2007 | 07:46 PM
I was just thinkin' "Cathorse" myself. I'm sorry again, I just couldn't help it. [&o]
Old Aug 27, 2007 | 08:01 PM
78buckshot's Avatar
Sam could do like we did on the Jimmy (GMC) diesels, just pour it on the top of the motor, it'll soak in somewhere.
Old Aug 27, 2007 | 08:22 PM
Yup, clean oil on the top, dirty oil on the bottom.
We called 'em "Screamin' Jimmys", a truck with straight pipes,that sounded like a hot rod.
Old Aug 27, 2007 | 10:45 PM
Dogcow750's Avatar
Thanks guys. The after-market valve covers threw me. Turned out to be a vented cap on the right side; pulled straight off. Just went for a drive on the highway and the engine purred.
Sam
