vapor lock
my 1977 vette runs great intill it gets hot. the fuel line is also hot. then it runs like theres a vacum leak is this vapor lock? yes i will move the fuel line soon.i smell gas when i shut off car.there is no leak any where. then it is hard to start.
tommytunes |
RE: vapor lock
I'm on here investigating the same problem. On going, have tried everything we can think of....still...dies and doesn't want to start...anyone?
RE: vapor lock
This problem bugs me, one would think if your fuel pump is good and the filters clean, you would have a constant supply of fuel. When the engine quits pour a cap full a gas down the carb.
RE: vapor lock
i moved fuel line far away from headers.put a thick gasket from edelbrock under the carb to keep the heat away from the bottom of carb.it seems to work much better.now i have to replace intake gasket, oil splashing out on back side. the under hood heat is crazy hot.i have a clothes pin on fuel line it supose to help.
RE: vapor lock
Hard starts when warm, gas smell, excessive heat.....sounds like timing is way out of adjustment
