vapor lock
Old Jun 27, 2006 | 02:21 PM
tommytunes's Avatar
Default vapor lock
my 1977 vette runs great intill it gets hot. the fuel line is also hot. then it runs like theres a vacum leak is this vapor lock? yes i will move the fuel line soon.i smell gas when i shut off car.there is no leak any where. then it is hard to start.
tommytunes
Old Jul 8, 2006 | 07:09 PM
minstrel's Avatar
Default RE: vapor lock
I'm on here investigating the same problem. On going, have tried everything we can think of....still...dies and doesn't want to start...anyone?
Old Jul 9, 2006 | 02:57 AM
R Rocks's Avatar
This problem bugs me, one would think if your fuel pump is good and the filters clean, you would have a constant supply of fuel. When the engine quits pour a cap full a gas down the carb.
Old Jul 11, 2006 | 04:36 PM
tommytunes's Avatar
i moved fuel line far away from headers.put a thick gasket from edelbrock under the carb to keep the heat away from the bottom of carb.it seems to work much better.now i have to replace intake gasket, oil splashing out on back side. the under hood heat is crazy hot.i have a clothes pin on fuel line it supose to help.
Old Jul 11, 2006 | 11:12 PM
toml14's Avatar
Hard starts when warm, gas smell, excessive heat.....sounds like timing is way out of adjustment
73Vettehead
May 15, 2011 11:33 PM
Baudier
Jun 19, 2008 10:27 PM
blueshark
Nov 6, 2007 10:00 AM
bigbob
Oct 5, 2006 08:45 PM
pgeders
Aug 1, 2005 01:03 PM
