Wiring question
Seem to have lost 2 wiresbehind the speedo and tach: 1969-350: Mounted on the rear of the tach. is the "w/s wiper door control solenoid".This solenoidhas 2 flat, male electrical connectors. Can anyone tell me where these two original wireswould lead or perhaps the color of the wires and maybe if they are two seperate wires with each a female connector or two wires going into a dual female connector? Any and all help will be appreciated. Thanks
Since many of you looked in and had no answers and since I finally figured it out myself, I will list the answers and hope it helps someone down the line. 1st. There are 4 wires not 2. There are 2 light blue wires and 2 yellow wires. These are connected to a double, hard plastic, female, slip on connector and the connector fits the 2 male posts on the wiper door solenoid. 2nd. The light blue wire starts at the wiper switch, runs to the solenoid then into a large loom that runs to a positive battery source. The yellow wire starts at the relay locatednear the actuator canister, runs to the solenoid and then into a large loom which goes to a negetive ground. If this circuit is compromised the wipers will notfunction properly. Thanks for looking in.
