"Change Oil reset
I have a 1995 vette and I changed my oil about 200 miles before it was due. Now my "change oil" light has come on and my manual doesn't indicate how to shut it off or reset it. What do I do?
RE: "Change Oil reset
buy a haynes or chiltons manual. they tell you how to turn it off. It isnt that hard once you see how to do it, but its something you probably wont remember. and unless the people that changed your oil (if it isnt you that is) own a c4, they will have NO idea how to do it. they barely remember to put the bolt back on half the time. good luck and ill post how to turn it off after work but im runnin late right now.
So happens I had to have my "change oil" light reset 2 days ago on my 92. Process should be the same. Here is the procedure. Hope this helps.
1. Turn ignition on, press ENG/MET button and release, then press ENG/MET button again within 5 seconds. 2. Within 5 seconds of step 1, press and hold the GUAGES button until the "Change Oil" indicator begins to flash. Hold GUAGES button until indicator stops flashing and goes out (approximately 10 seconds). 3. I indicator was not successfully reset, turn ignition off and repeat reset procedure. Good Luck! |
Yeah, thats the process i was going to post but redvet got to it before me.. Hope it helped.
Thank you ...it worked
grabie |
For future ref have another look at your owners manual as mine does show how to reset the oil change monitor. I also know a site where you can download 20 meg pdf file of the complete owners manual for some vettes including the 95.
Can you post that manuel link? That would e a real help. Thank you
yes that link would be great! thanks.
