"Change Oil reset
Old Mar 10, 2006 | 01:01 AM
grabie's Avatar
Default "Change Oil reset
I have a 1995 vette and I changed my oil about 200 miles before it was due. Now my "change oil" light has come on and my manual doesn't indicate how to shut it off or reset it. What do I do?
Old Mar 10, 2006 | 08:20 AM
94blackC4's Avatar
Default RE: "Change Oil reset
buy a haynes or chiltons manual. they tell you how to turn it off. It isnt that hard once you see how to do it, but its something you probably wont remember. and unless the people that changed your oil (if it isnt you that is) own a c4, they will have NO idea how to do it. they barely remember to put the bolt back on half the time. good luck and ill post how to turn it off after work but im runnin late right now.
Old Mar 10, 2006 | 02:05 PM
redvet's Avatar
So happens I had to have my "change oil" light reset 2 days ago on my 92. Process should be the same. Here is the procedure. Hope this helps.
1. Turn ignition on, press ENG/MET button and release, then press ENG/MET button again within 5 seconds.
2. Within 5 seconds of step 1, press and hold the GUAGES button until the "Change Oil" indicator begins to flash. Hold GUAGES button until indicator stops flashing and goes out (approximately 10 seconds).
3. I indicator was not successfully reset, turn ignition off and repeat reset procedure.
Good Luck!
Old Mar 10, 2006 | 08:59 PM
94blackC4's Avatar
Yeah, thats the process i was going to post but redvet got to it before me.. Hope it helped.
Old Mar 11, 2006 | 03:24 AM
grabie's Avatar
Thank you ...it worked
grabie
Old Mar 12, 2006 | 11:24 PM
muzikman's Avatar
For future ref have another look at your owners manual as mine does show how to reset the oil change monitor. I also know a site where you can download 20 meg pdf file of the complete owners manual for some vettes including the 95.
Old Apr 19, 2006 | 10:42 PM
tcrote5516's Avatar
Can you post that manuel link? That would e a real help. Thank you
Old Apr 19, 2006 | 11:54 PM
joecls's Avatar
yes that link would be great! thanks.
TJL74Vette
Jun 20, 2007 09:12 PM
serg5000
Jun 2, 2007 10:00 AM
kruser
May 22, 2007 08:43 AM
SLJ2137694
May 16, 2006 02:32 PM
joecls
Apr 18, 2006 11:57 AM
