18 inch wheels for c4 ??
Old May 8, 2006 | 02:24 PM
89rdstr's Avatar
Default 18 inch wheels for c4 ??
can you guys tell me if i can put a set of 18x10 wheels on my 89 c4 without any problems? also my electronic control hvac system always blows hot air even in the off position, do you have any input on this as allways thanks in advance for any help.
Old Jun 19, 2006 | 11:56 PM
89rdstr's Avatar
Default RE: 18 inch wheels for c4 ??
Okay I'll answer my own post. The wheels on this car are 06 Z06 wheels, 18 x 9.5". Front and rear, tires are 275-35-18 and are the same diameter as the original 17s. They fit without any problems and look great!
[IMG]local://upfiles/2048/91A967A608BE41FAAB16C669A33774E9.jpg[/IMG]
Old Oct 24, 2007 | 06:45 PM
mexvette's Avatar
Quick question , I am bidding on a set of 18 x 9.5 ZO6 wheels for my 95 vette, since you have the same size wheels I am about to bid on I am curious if there is any problem with the tires up front rubbibg when you turn since they are wider than the 245's that come with my car? any info on this will help drastcly. thanks in advance.
Old Oct 24, 2007 | 09:03 PM
Toms94's Avatar
Should be no problems putting the 275's up front. Some of the 95's came with them from the factory. All the 91 and 92's and all Z07 optioned cars (91-95) came with 275's all around. The ZR1's also came with 275's up front. In 96 the Z51 equipted cars had 275's all round and GS coupes had them on the front. As long as the total height of the wheel/tire is the same it shouldn't have any trouble rubbing the front.
Old Oct 25, 2007 | 03:24 PM
AXE's Avatar
AXE
i had 18 inch konigs on my 85 they were only 8 inches wide and i needed to have 2 inch spacers because of the offset on the wheels they didnt rub, i since have removed them as i didnt like having spacers on the car . they did fit without the spacers but they were too far in for my liking, now i am running ZR-1 wheels on it and it looks great. hopes this helps
crashbug
Mar 13, 2007 05:04 AM
Black86vette
Dec 19, 2006 06:35 PM
Black Cloud
Nov 11, 2006 10:33 AM
Lee Willis
Aug 8, 2006 09:13 PM
