1984 won’t fire
Old Aug 30, 2021 | 02:08 PM
Pat Fowler's Avatar
Default 1984 won’t fire
I’ve had this car since it was new, went to start it the other day and it turns over fine but won’t fire. I can hear the fuel pump come on when key is in run position. I took throttle body cover off and sprayed a little starter fluid and it fires right up, for a second. I pulled the fuel line into the passenger side throttle body off and cranked the engine and it’s pumping gas. Anyone got an idea as to what I need to check now ? Thanks, Pat.
Old Aug 31, 2021 | 02:35 PM
Welcome to the forum. I wonder if the injectors are firing.
Old Aug 31, 2021 | 02:59 PM
Pat Fowler's Avatar
Crossfire injection, almost carburetors, have a bad rap but I’ve had no problems over the 30+ years I’ve owned it but may very well have some now. Suggestion as how to diagnose it ?
Old Aug 31, 2021 | 03:40 PM
I thought the Crossfire throttle bodies had an injector in them.
Old Aug 31, 2021 | 08:59 PM
Pat Fowler's Avatar
I’m sure you are correct but after removing the intake I’m looking at what resembles two carbs each has what looks like a choke plate that when I sprayed starter fluid into the engine fires. As you maybe able to discern I really don’t know what I’m dealing with as far as diagnosing what maybe happening !
I’m in the process of changing out the window regulators and getting new tires so when I get this to a real mechanic I can drive it back home,!
Old Aug 31, 2021 | 10:56 PM
While I've never worked on a TBI system, the fact that it just quit all at once would leave me to believe that maybe the injectors are not getting the signal from the ECM.
Please let us know when you find out what the solution to the problem is.
Old Oct 8, 2021 | 10:24 AM
Distinguished879's Avatar
Crossfire throttle bodies do have injectors in them.. If you can get someone to crank the engine while you look at the throttle.body injector, you should be able to see a fan like spray of gas coming from the injector. If gas isn't coming out then you could have one of a few problems. Since you already know that gas is getting to the throttle body, it must be related to the ECM , the injectors or the pressure regulator.
Old Oct 9, 2021 | 01:02 AM
Welcome to the forum. Thanks for the info.
Old Oct 11, 2021 | 12:21 PM
Pat Fowler's Avatar
Thank you for your response, it was the injectors ! They both where clogged, they have been cleaned and the car is running well ! Thanks again, Pat.
Old Oct 13, 2021 | 10:04 PM
Default Clogged injectors, followup
The next question you should ask is -what caused the injectors to clog up? You may want to inspect/flush your gas tank, fuel lines and replace the fuel filter. That crud had to come from somewhere.
