1986 AC leak
Every year since 2017 I’ve taken my car in to a Chevrolet dealer and/or private shops to have the AC repaired. To date, the evaporator core, the compressor, the dryer, a conversion kit fitting and the long silver tube running along the right side of the engine have all been replaced. The system is recharged and lasts for approximately 2-3 months. They have put dye in the system and found a pin hole leak in the silver tubing I mention above. I sent to Old Air in Texas for the replacement part as no one locally could find one. Again, 2-3 months after installation and charge and failure. Not sure what to do next. I would appreciate any ideas anyone might have.
Welcome to the forums! Sorry to hear you are Loosing your cool. (sorry not funny this time of the year!) Your best choice is to have them fix it again, I question the quality of the parts they are using. (import?) After 3 months no warranty right? You can replace the long silver line (high pressure liquid gas line) or if the pin hole in a straight area,(no bends) they could cut the line at the pin hole and install a 3/8in tubing union if you have the space to do that. Unions are only a few dollars.. If you have a replacement line coming have them install it and hope for the best. you will be good for another 3 months, Right? I did see A/C lines on Corvette Central. Good luck!
Welcome to the forum. Obviously there's still a leak somewhere besides the pinhole leak you found in the high pressure line. Surprised they can't find it if they put dye in the system. After they do these repairs, do they pull a hard vacuum on it and see how long it'll hold? If it doesn't hold a vacuum then there's no use of putting more parts in it until you find where the leak is.
It is possible to lose a charge over a three month time period thru a pin hole, Even more so on the high pressure side. Have them repair the leak. evacuate the system and if it holds vacuum for 30 minutes then charge it. After the charge is done have them take an electronic snooper over the entire system to detect any leaks..
If the shop you're taking this to is a competent A/C repair shop then you shouldn't have to tell them this. For instance when they pull the vacuum to see if the leak was repaired, they should break that vacuum with freon and then pump it down again before recharging this system. Also if the system has been without any freon in it and had a leak, then the desiccant should probably be replaced in it.
Yes it is unusual to have this much trouble! Worked in a chevy dealership years back in the early 80`s, Installed many A/C units in new cars and pickups, and they had very few problems. But once in a while someone would get that vehicle that would come in and we would call it the problem child! But it did get fixed eventually. I think you have that child! Be sure to vent your frustration about this situation so they take you serious and get it fixed right! I`m sure it will happen!
