1989 exessive fuel consumption
Old Aug 12, 2006 | 02:08 PM
dsshavinfun36's Avatar
Default 1989 exessive fuel consumption
this problem comes and goes. start car and it loads up smokes and gets 5 mile to the gal. had put on snapon comp it says tpc bad replaced and set at 54v. it started running great for 5 or 10 min. then did it agin. comp says tpc out of adjustment agin. cleared codes
now it says i have 8 or more things not right or failing. so i replaced computer with new one. it worked for 30miles started loading up and smoking agin.iny input would be helpful. Thanks
Old Aug 14, 2006 | 02:10 AM
raisinbran's Avatar
Default RE: 1989 exessive fuel consumption
What exactly are the codes you're getting??? They are usually right, and can help pinpoint you to the source of the problem.
Old Aug 14, 2006 | 09:59 AM
Pull the vacuum hose off fuel pressure regulator and see if there is any fuel in it. Also check fuel pressure to see if pressure is to high. Also, post the code numbers to see if we can help.
oneamous
Oct 16, 2014 11:03 AM
Bilbowk
May 21, 2012 09:19 AM
slayerz06
Feb 10, 2009 10:48 PM
reactor2
Sep 4, 2006 09:33 PM
doc hollliday
Jun 18, 2005 01:51 AM
