1994 coupe with 6 speed manual tranmission
was wondering if anyone might know what might be makin this noise when i got the car it has a winein noise when you are sitting there with the car out of gear and clutch out , when u mash clutch it it stops i thought it was something to do with the clutch so after i replaced it when it was bad i put new one in and i still have same noise cant figure if its natural for it to make the winein noise was wonder if anyone had any ideas
RE: 1994 coupe with 6 speed manual tranmission
This car would be about the same as my 92 6 speed, I do not have anything I would describe as a whine noise, but a lot of gear rattle in neutral with the clutch out is normal for this car. If you have a whine inneutral at a stop with the clutch out, it probably is a bad bearing in the transmission, probably the input bearing where the shaft goes into the transmission, it will only be turning with the clutch released.
