84 vette
I bought an 84 vette, and it has a carburetor, 4 barrel. My problem is it is hard to start. Once it's started,it will start right up anyother time during the day. I've heard , to replace the fuel pump to a upgrade. Help
RE: 84 vette
Could simply be that the choke is not working correctly. If it run okay once started, hard to believe the fuel pump is messed up.
RE: 84 vette
Do you know what carb is on it? Is it a quadrajet? Quads have a nasty habit after a while of well plugs leaking gas from the bowl and emptying the carb of fuel and causes extended crank times until fuel bowl is full.
RE: 84 vette
what kind of carb??? what size carb??? and is the choke working right??? sounds like its a choke problem, is it prone to d it on really cold days??? need more info to solve the problem
