84 vette
Old Jun 2, 2007 | 08:06 PM
paparacecar's Avatar
Default 84 vette
I bought an 84 vette, and it has a carburetor, 4 barrel. My problem is it is hard to start. Once it's started,it will start right up anyother time during the day. I've heard , to replace the fuel pump to a upgrade. Help
Old Jun 2, 2007 | 08:09 PM
Default RE: 84 vette
Could simply be that the choke is not working correctly. If it run okay once started, hard to believe the fuel pump is messed up.
Old Jun 2, 2007 | 08:26 PM
Do you know what carb is on it? Is it a quadrajet? Quads have a nasty habit after a while of well plugs leaking gas from the bowl and emptying the carb of fuel and causes extended crank times until fuel bowl is full.
Old Aug 6, 2007 | 04:47 PM
84corvetteC4's Avatar
what kind of carb??? what size carb??? and is the choke working right??? sounds like its a choke problem, is it prone to d it on really cold days??? need more info to solve the problem
