'86 C4 /w 4 3 Doug Nash L98
I have found that when I take off hard or under high rev. shiftswhen the engine is hot or cold that the it pings like crazy. I have not had any codes and the motor has been setup to factory specs. so to past emisions. I also run 92 or higher octane and perfer not to rely on additives. Will the Knock sensor go badw/o setting a code out?
RE: '86 C4 /w 4 3 Doug Nash L98
Knock sensor failurePROBABLY would set a code.
Are you sure the timing was set correctly? Does the engine burn oil? Are spark plugs the correct heat range? Any engine modifications? |
