'86 C4 /w 4 3 Doug Nash L98
Old Jan 27, 2008 | 12:15 PM
YANKEECORVETTE's Avatar
Default '86 C4 /w 4 3 Doug Nash L98
I have found that when I take off hard or under high rev. shiftswhen the engine is hot or cold that the it pings like crazy. I have not had any codes and the motor has been setup to factory specs. so to past emisions. I also run 92 or higher octane and perfer not to rely on additives. Will the Knock sensor go badw/o setting a code out?
Old Jan 28, 2008 | 10:09 AM
Tacky's Avatar
Default RE: '86 C4 /w 4 3 Doug Nash L98
Knock sensor failurePROBABLY would set a code.
Are you sure the timing was set correctly?
Does the engine burn oil?
Are spark plugs the correct heat range?
Any engine modifications?
vet84
Feb 26, 2010 01:43 PM
BurnOut
Mar 4, 2009 03:04 PM
YANKEECORVETTE
Oct 2, 2008 11:27 PM
All2kool
Oct 24, 2006 11:49 PM
poxic
Jul 24, 2005 01:58 PM
