'86 problem
Old Oct 2, 2006 | 11:01 PM
rwolak's Avatar
Default '86 problem
i've seen a number of threads on the MAF but i would like suggestions.
my '86 runs fine with the MAF unplugged. when i plug it in, the car won't idle at anything less than around 1400rpm. is this telling me the MAF is bad? or could it be something else?
tia
Old Oct 4, 2006 | 02:53 AM
raisinbran's Avatar
Default RE: '86 problem
do u get any codes? i cant imagine the car running good with it unplugged
Old Oct 4, 2006 | 02:54 AM
raisinbran's Avatar
anyway you could get your hands on a working MAF to see if it makes your car run better?
Old Oct 4, 2006 | 09:36 AM
More than likely the MAF is bad. By unpluggung it, you are putting the ECM in a backup fuel mode where it uses a preprogrammed fuel curve to match throttle position. Several places make rebuilt MAF, namely anyone who carries A-1 Cardone. I have had bad rebuilt ones from them, so buyer beware. I had the same problem with my 86 and the rebuilt one I used just dumped fuel and gas fouled spark plugs. Ended up putting a new A/C Delco one in to the tune of $450.00. So good luck. [8D]
reactor2
Sep 4, 2006 09:33 PM
