86 Suddenly died
Old Aug 8, 2006 | 04:27 PM
1fast86's Avatar
Default 86 Suddenly died
I have an 86 which has not had any problems. The other day I was driving back from the corner gas station and at 25 mph discovered I was coasting. Everything just shut down. I coasted to a stop and tried restarting. The engine will crank just fine but does not appear to be getting fuel. I have read the other posts and was wondering if any ideas or if anyne has had the same thing occur. There was no sputter or rough engine before it shut off. Thanks. This is a great site for us new owners.
Old Aug 9, 2006 | 05:19 AM
d93vette's Avatar
Default RE: 86 Suddenly died
was up, a car needs fuel,air and spark to run. what i would do to check which sys. that might be the problem is remove maf and spray alittle starting fluid in the intake. if it kicks over, spark is good[doesn't mean the timings right] and it a good chance it the fuel sys. if it won't kick, take a look at the ignition. it works sometimes, and sometimes its not that simple, but just check one thing at a time. you have to find out were to start.
Old Aug 9, 2006 | 06:05 AM
1fast86's Avatar
Thanks d93vette.
Old Aug 10, 2006 | 06:51 AM
raisinbran's Avatar
when u turn the key to "on", do u hear the fuel pump, or can u squirt some fuel out of the schrader valve on the fuel rail?? go and pick you up one of those cheap spark testers...you hook one end up to the wire boot, and ground the other.
Old Aug 12, 2006 | 06:33 AM
1fast86's Avatar
Thanks raisinbran. I had someone listen for the fuel pump and they heard nothing. I am guessing the fuel pump is the original. I have ordered a performance pump from Ecklers and should have it Monday.
Old Aug 14, 2006 | 02:14 AM
raisinbran's Avatar
It could be the fuel pump, but it could also be as simple as the relay, since the pump will not operate normally if the relay is bad. If you have a volt meter you can check and see if 12v is getting to the pump.
Just a tip, make sure you replace the sock at the bottom of the pump when you put in the new one...ask me how i know (thank god for the warrenty )
Old Aug 14, 2006 | 05:03 PM
1fast86's Avatar
Thanks raisinbran. I will check that. Also I noticed Chiltons says I have to pull the gas tank on an 86 to change the fuel pump. Is that correct or can I just go in through the filler door like the 90s.
Old Aug 15, 2006 | 02:08 AM
raisinbran's Avatar
Yes you can go through the filler door...I cant imagine what a pain that would be to drop the tank in the vette. Take some of that gasoline and throw it on the Chilton's.
Old Aug 15, 2006 | 11:41 PM
Chilton manuals are the laugher of our tech worlds. None are completely good, but we use Alldata. And yes, pump comes out easily though the fuel door. [8D]
Old Aug 17, 2006 | 03:39 AM
1fast86's Avatar
Thanks mech259 and raisinbran. I will use the Chiltons to start my next barbeque but I am guessing it might leave a bad taste in my mouth!!!
