89 C4 shimmys at higher speeds
Old Mar 22, 2007 | 05:54 PM
mafulton's Avatar
Default 89 C4 shimmys at higher speeds
My c4 shimmys at speeds in excess of 60mph. I have new wheels, just balanced and my understanding is that wheel balancing is not really a factor over 60mph. Does anybody have any ideas as to what might cause this (alignment, etc.) Thx
Old Mar 22, 2007 | 09:27 PM
Batwing's Avatar
Default RE: 89 C4 shimmys at higher speeds
I have the same problem...I think its the tires. They are not new and because I did'nt watch the tire pressure properly, I have a funky wear pattern. I believe that when I get the new tires (and so does my mechanic) that the problem ....hopefully will go away.
Old Mar 22, 2007 | 10:07 PM
Black86vette's Avatar
What brand of tires. I hope they are not the run flat tires. They are terrible. Michelin pilots are probably the best. I have BF Pro-Force[&:]
Old Mar 23, 2007 | 12:29 AM
You might have a wore out tie rod end. Slack in the tie rods will cause shimmey problems. [8D]
Old Mar 23, 2007 | 12:44 PM
Batwing's Avatar
my shake dose'nt start till 55 or so. I got my car at the end of last summer. I knew the tires were messed up. Now it's spring....need new tires soon. The michelin pilots........thanks foor the tip. Everybody has an opinion on tires. But those are probobly the way to go. When I do the change I'll have them check the tie rod ends too. Thanks again...
Richard Sattora
Nov 1, 2014 04:01 PM
vector89
Sep 1, 2012 12:58 AM
Vette84
May 21, 2007 06:31 AM
