90 ROADSTER NO START HELP!!
Old Jul 24, 2006 | 05:09 PM
KRATEFREAK's Avatar
Default 90 ROADSTER NO START HELP!!
OK PLEASE HELP IM A FORD TECH NOT TO GOOD WITH THESE OLD VETTES I HAVE A 90 VETTE IF IT SITS OVER NIGHT IT STARTS & RUNS FINE FOR ABOUT FIVE MINUTES THEN I LOOSE INJECTORS & IT WONT RUN AFTER THAT I HAVE REPLACED THE COOLANT SENSOR MAP & FUEL PUMP I BOUGHT A USED ECM IT DOSE THE SAME THING HELP PLEASE COULD THE PROM DO THIS ?? THANKS IT DOSNT LOOSE SPARK
Old Jul 24, 2006 | 09:59 PM
raisinbran's Avatar
Default RE: 90 ROADSTER NO START HELP!!
fuel, air, spark
start with the basics, and go from there. check fuel pressure. jump the terminal and check for codes...i bet you have some.
Old Jul 24, 2006 | 11:15 PM
KRATEFREAK's Avatar
THANKS FOR THE REPLY BUT I THINK I HAVE COVERED THE BASICS THEIR ARE NO CODES IM LOOSING INJECTOR PULSE COULD THE PROM CAUSE THIS THANKS
Old Jul 25, 2006 | 10:01 AM
When you loose pulse, check to see if you have 12v on one side of the injector connector. The ECM grounds the injectors to control pulse. There are 2 injector fuses, left bank, right bank. Won't be a problem with fuses unless there is a connection problem, because the car restarts eventually. Prom could be the prob, but not likely because usually they are either not working or are working -- not intermittant. You might have an injector shorting out and when that happens, the ECM shuts down the quad drivers built into itself for protection. Ohm check them, should be around 15 ohms with no more than .5 ohm variance. See if you have no pulse on both banks when it quits. Good luck. [8D]
Old Jul 25, 2006 | 02:09 PM
KRATEFREAK's Avatar
THANKS I NEVER LOSE MY 12V BUT AS FOR ONE BEING SHORTED I HAVENT CHECKED I THINK YOU MIGHT BE ON TO SOMTHING THANKS!!
Old Jul 25, 2006 | 04:31 PM
KRATEFREAK's Avatar
THANKS MECH259 IT WAS A INJECTOR SHORTED OUT THANKS AGAIN
Old Jul 26, 2006 | 07:35 PM
Glad I could help. That happens a lot @ my shop. We replace several injectors a year. [8D]
sawbuck
Dec 23, 2006 02:43 PM
PAY2PLAY
Dec 20, 2006 04:16 PM
fencilar
Oct 5, 2006 01:45 PM
06 Vette
Jan 22, 2006 10:09 AM
ram99vette
Nov 8, 2005 08:45 PM
