94 'Vette Headlight "on" chime
Old Oct 25, 2006 | 05:35 PM
hc91237's Avatar
Default 94 'Vette Headlight "on" chime
Users manual to my lovely 94 vette indicates that there should be a chime that sounds when I inadvertanly leave my headlights on and take the key out of the ignition. Now, no chime sounds, and I have accidentally left my lights on twice.
Is this fuse based or is this a short somewhere.
Old Oct 27, 2006 | 10:50 PM
Black86vette's Avatar
Default RE: 94 'Vette Headlight "on" chime
I have a similar problem. When my car is RUNNING and I turn on the headlights it chimes...I am trying to trace it. Possibly your problem is your door switch may be stuck or it may be a short which is what mine apparently is. If you try the door switch get back and I can help you trace the short as I am working on it myself. Goodluck
Old Oct 27, 2006 | 11:33 PM
The chime for the door works on a ground circuit. The switch completes a path to ground for the chime and light. My 86 had a similar prob in that the hatch switch on the driver door would not open the hatch. Come to find out the door switch was not opening all the way to not only turn the lights on, but to supply ground for the hatch switch to trip the relay for the hatch solenoid.
Old Oct 27, 2006 | 11:35 PM
Do you get a chime when you leave ket in ignition and open door?
Old Oct 28, 2006 | 05:32 PM
I want to disengage that stupid chime. Going down the road at nighttime is a P.I.T.A....I want to jerk it out. It does not help me any but is a nuisance.
monte_350
May 14, 2022 02:02 PM
slovette
Technical Diagram Help
Apr 12, 2011 07:16 PM
yayaman
May 26, 2008 05:21 PM
81GAVette
Oct 17, 2006 07:18 PM
dwhite
Oct 23, 2005 10:59 PM
