95 Coupe
Old Sep 3, 2007 | 08:36 PM
95vettetx's Avatar
Default 95 Coupe
Hey everyone,
Got a big rattle in the roof of the coupe. It can be heard if the hardtop is on or off the car. It sounds like somehting pretty heavy is loose in there. I got to admit, I'm not very handy, although I did notice some screws in the interior of the car. Has anyone else had this same problem or have any tips or suggestions for me?
Old Sep 4, 2007 | 06:24 AM
RudeDog's Avatar
Default RE: 95 Coupe
Well the obvious and hopefully for you the easiest/cheapest fix would be if you didn't get your
torga top on your coupe screwed in correctly or tight enough. You don't want to overtighten but
you can install those things incorrectly. I've been advised (and found it to be correct) that you lightly
tighten the four screws first and then final tighten the back first then the front. This helps pull/align the
front ones for final tightening but don't overtighten. Good luck
Old Sep 5, 2007 | 07:11 PM
Viscount's Avatar
ORIGINAL: 95vettetx
Hey everyone,
With the roof "off" remove the plastic covers above the sun visors. Might be something loose in there. You may also have to remove the trim panel on the "B" pillar. Possibly the culprit is located in there??????
Old Sep 6, 2007 | 06:19 PM
95vettetx's Avatar
Thanks for the feedback guys. I really appreciate it. I will check on these options and see if that helps correct the situation.
Old Sep 6, 2007 | 07:15 PM
I like to start all four (figure A), then lock down the front screws first, since the rears screws will still be aligned straight into the bolt hole(figure C), whereas lockin' the rears down first might make the front screws pull out of alignment (figure B).
[IMG]local://upfiles/5243/C2113AE577B8471EA06F19D1AFF5A676.jpg[/IMG]
Old Sep 7, 2007 | 12:35 AM
84corvetteC4's Avatar
I just tighten the hell out of all of my four untilI cant get then any tighter, sooo far soo good ( I wouldnt recommend anyone to try this on their corvette,I only do it to mine b/c when I accelerate rapidly at wot it twist and the screws somtimes come loose[]
